Question about Pride Mobility Products Casual CL30KD Lift Chair Chestnut
MY CHAIR IS IN THE RECLINING POSITION AND IT WON.T COME BACK TO A SITTING POSITION HELP!
  • 1 more comment
  • SERG4517 May 02, 2011
    I need a phone # for pride provider in Bergen County New jersey Thank you
  • Comfortable Life
    Comfortable Life Jun 23, 2019
    You have to adjust it correctly. There are a lot of parts and accessories of your recliner chair. Here are a few helpful resources about adjusting your recliner
    http://www.chairsadvisor.com/4-best-ways...https://www.youtube.com/watch?v=eGYS17hv...https://www.wikihow.com/Adjust-a-Recline...http://www.chairsadvisor.com/best-reclin...https://www.youtube.com/watch?v=t-R2fMpu...
  • David1207
    David1207 Aug 29, 2019
    There should be a recline adjustment lever which you should use. However If this is not the case then either you should look for an alternative and purchase another chair or contact support system.
    https://theluxurychairs.com/best-living-...
    Genius:
  • 1,622 Answers
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Instructions
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
If your recliner won't work and if have some problem this guide may help you to fix recliner visit 7 Key Tips On How To Fix Recliner Chair Mechanism Recliner Genie
Posted on Jun 03, 2018
    President:
  • 2,080 Answers
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.pridemobility.com/pdf/owners_manuals/us_liftchair/us_lift_chair_series_358_520_530_550_om.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Make sure the power cord to your chair's power adapter / transformer is plugged into a live wall outlet and the green light is illuminated on the transformer. You can check to see if the wall outlet is live with a plug in reading lamp or with a voltmeter if you have one. If the outlet has no power, then check the house's main electrical breaker panel and reset the breaker for that circuit if necessary.
Next make sure the cord form the chair to the transformer is also plugged in securely.
Also make sure the quick release connector for the chair's Push Button Hand Control Unit is fully plugged into the control box.
See page 9 of the manual for proper setup instructions with detailed illustrations of all the cables and connections.
If your chair has the dual lift motors, then you may need to reset the motor timing to get them to operate normally again. See page 24 of the manual for detailed instructions and illustrations on HOW TO RESET THE MOTOR TIMING.
Your transformer should be fitted with two 9 Volt batteries which would enable the chair to return to the upright position in case of a power failure. Check the battery compartment in the transformer and replace the batteries with new ones if required. See page 16 of the manual for details.
Your motor may also just be overheated. Try leatting it cool down for an hour, then try operating the hand controls again.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
SOURCE:
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Aug 02, 2014 | Pride Health & Beauty
Nina power recliner chair stuck open
Look where the control button is it should be a little space to where you can stick a needle or nail in that the reset button I want you reset it then you should be able to get to a recliner to go back down
Apr 16, 2014 | Furniture Nina Fabric Sectional Sofa,...
The spring snapped on lafer recliner chair
I bought replacement spring at Lowes
This was Hillman brand replacement spring
Five eight x three and a quarter x 072 inch type
2 springs per pkg works great
Apr 06, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
I'm thinking of getting the full reclining lazyboy loveseats, how much space I need to leave between the chairs and the wall?
If it is fully reclining you need to leave a little bit more than the height of the chair's back. For example: if the back height is 19", then you need to leave about 20" between the chair and the wall behind it.
May 29, 2012 | Furniture
I have a quantum 600 tilting chair, when I put the chair in the sitting position from the reclining position, the little red light came on and now my chair will not move, have no manual for this chair
I'm having the same problem with the red light on my Q6000Z PC not going out, no matter what position that the seat is in. Yesterday I lifted the seat to change my furnice filter and when I lower the seat light wouldn't go out and the chait would not move. and yes I did try going up and down several times. I do have a Quantum joystick controler, but I don't know how to use it. Can anybody help me? Or at least give me a website name where I can go to fond out.
Feb 14, 2011 | Electric Health & Beauty
Invacare power chair model #1089384; is stuck in the reclining position and won't come back up
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Jan 18, 2011 | Invacare Health & Beauty
Legrest try to put them on
open up leg rest lever(spring loaded) and put on to pins from base of chair. Usually easier to put on in the open position (as if you were getting out of chair)
Mar 22, 2009 | Viper Plus Lightweight Reclining...
How to change reclining position
Viewed from behind, there are two cords with pull tbs that are gathered together in the center of the seatback with a black plastic gather. These two cords are loosen or tightened to raise or lower the seat back recline position.
Mar 01, 2009 | Graco MetroLite Air 6116 Stroller
Pride Mobility Products Casual CL30KD Lift Chair Chestnut  Logo
14,232 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
