Posted on May 01, 2011
Why is the blue light flashing on my hp laserjet p1102w printer?what does it mean?
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
12627
Points
38
The blue light on your printer shows the status of the wireless connection. If the light is flashing then this means that it is trying to connect to a network.
A solid light means that it has connected to a wireless network.
Please let me know if you would like help connecting your printer to a wireless network.
Thanks,
Andy
1helpful
2answers
I’ve reset my hp laserjet p1102w but it still won’t recognize my new router%.
Try changing the router password and try again to link the printer. Obviously, you would have to go back and pair. (link) all other devices in the network using the new password.
tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
Why does the printer beep when printing
to alert the user that their may be sensitive docs printing
Eror 52.0 scaner eror
The 52 error in most HP printers is not reversible, you must replace the scanner if the is cost worthy.Might want to unplug printer from the power source for 30 minutes and retry, before changing the scanner unit.
Hp p1102w offline
This worked perfectly, I hope it doesn't lose the connection again!
Phil D
www.TheBocX.com
Reset paper jam error HP P1120w
i have a hp p1102w laser jet, it's about a year old. Hp want 130 replace it, I only paid 100 for it. I have a blinking red light. It tell me paper jam, I can find no Paper that would make the jam. After two day we looked at it again, when we turned it back on it said out of ink. I knew that was no true, because I had just put new ink in it. Now it's back to paper jam. What do I do? Does anyone have any ideas?
2helpful
My i phone 4 does not recognize my wireless hp printer 4500
Currently to use iPhone to use printing you need a airprint enabled printers! below is a list of them!
HP Deskjet 3050A e-AiO HP Envy e-AiO (D410) HP Photosmart Plus e-AiO (B210) HP Photosmart Premium e-AiO (C310) HP Photosmart Premium Fax e-AiO (C410) HP Photosmart e-AiO (D110) HP Photosmart Wireless e-AiO (B110)-Europe and Asia-Pacific HP Photosmart eStation (C510) HP LaserJet P1102w HP LaserJet P1606dn
there are more to this list and for information check http://support.apple.com/kb/HT4356
1helpful
2answers
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
k24674
ADMIN Andrew
ADMIN Andrew
