Sir this is my last request As you known i have i have an acer aspire 4315 the original processor of my laptp is a intel celeron 540 which is 1.86 ghz i was thinking of upgrading it to a same celeron but a little higher that is to an intel 560 which is an 2.13 ghz will this atleast be safe or will it require a new good fan and a heatsink which fan if it requires will be the best and good for the new processor and a last thing which os will be the best in the processor vista or xp and the last which company is the best for ram of 4 gb and for a hardrive of 250 gb as i want to buy it Thank you very much for your kind hints.
Fan cooler for Celeron is usually the same for 540 and 560 Ghz, there should be no need to replace cooling system if you pass from 540 and 560
Whenever you operates on CPU and cooling system you need to monitor CPU temperature using Bios or a dedicated software. Here is a good software to check CPU temperature and Fan activity: SpeedFan Download.
Regarding the RAM, some seller like this one (UK seller).sells Trascends 2 GB modules, seller says they work on 4315, you can eventually ask them if there is any issue with bios version and if you need to upgrade bios.
Remember, CPU upgrade on a laptop is not a simple operation, be careful if you do it yourself, as it is easy to damage the laptop when taking it apart. Regarding RAM, main risk is incompatibility, If you live in UK the seller above guarantee compatibility with Acer 4315, double check by sending them an email before buying.
