Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the pull start? - Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
Andrew White
Level 3:
  • Poulan Master 2,239 Answers
  • Posted on May 01, 2011
Andrew White
Poulan Master
Level 3:
Answers
2239
Questions
Helped
909836
Points
5950
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
1helpful
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 • Garden
Why does my Sportsman 400 start by the pull cord, but will not start with the ignition. It turns over fine.
replace the battery as there is not enough charge to start and provide power for the ignition
when you pull start the max power is provided to the ignition system
Switch turns off
try pulling the starting rope a little bit out before you pull start it. If this does not work replace the switch.
My sthil fs 310 trimmer
Determine whether or not the engine is locked up by removing the plastic outer shell including the pull cable. The cable reel once dis-engaged from the crankshaft should freely pull out and retract on its own. If the cable reel is still hard to pull, you can replace the reel. Otherwise the engine is binding probably cheaper to replace the whole unit than attempting repair.
May 14, 2014 • Saws
G-force 3030 can't pull string to start? Engine
bad carburetor. replace it and that should solve the problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 04, 2013 • Garden
John Deere JS63 problems
Take the starter assembly apart (get the manual - Google it - they're free) and rebuild. Lube, W-40, whatever is sticking. Replace the primer bulb.
Oct 05, 2017 • Garden
5helpful
2answers
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
1helpful
Was running stopped it for 1/2 hour, and would not re-start
IT LOOKS LIKE YOU COIL MAY HAVE CRAPPED OUT ON YOU. THEY NORMALLY WILL QUIT WITHOUT WARNING
Mar 28, 2010 • Garden
I can't get it started. It was my Uncle's who
Tips for starting gas powered garden tools.
1.) Drain old gas and replace with new gas.
2.) Make sure oil/gas mix ratio is correct 50 parts gas 1 part oil.
3.) Pull spark plug and replace with a new one or clean the old one.
4.) Pull start with full choke until engine turns over. Then take choke off.
5.) Pull to start.
It should be that easy. If it doesnt start your problems may require a repair shop.
Aug 27, 2009 • Echo Garden
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
