What is the proper asking price for the Nodictrack Treadmill A2050 Model #NTL10851 as a used treadmill with only 700 miles on the walking belt? The Treadmill is in excellent shape. Everything works on it. I have never had any problems or never had to replace any parts. Everything on the Treadmill still works as if it were knew. I just want to be fair in my asking price of a used treadmill. Thank you in advance for your help. Susan
hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck.
Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video.
ok
Discription: WALKING BELT W/FASTENERS, Part # 193575, Model # PCTL49820, Price $48.83 In humble opinion you should replace the part, it sounds like an accident waiting to happen Call Icon Fitness @ 800-999-3756 and give them the info above.
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt
tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Sounds like the actual function pad is causing the problem in some cases you'll be able to purchase that part and sometime with iconfitness you have to buy the entire console for a hefty amount you may call them @ 1-800-999-3756 or go to their website iconfitness.com. Good Luck
If the walking belt is overtightened, treadmill performance
may decrease and the walking belt may become
damaged. Remove the key and UNPLUG THE
POWER CORD. Using the hex key, turn both idler
roller bolts counterclockwise, 1/4 of a turn. When the
walking belt is properly tightened, you should be able
to lift each edge of the walking belt 3 to 4 in. (8 to 10
cm) off the walking platform. Be careful to keep the
walking belt centered. Then, plug in the power cord,
insert the key, and run the treadmill for a few minutes.
. If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Using the hex key, turn both rear roller bolts clockwise,
tightened, you should be able to lift each edge of the
walking belt 2 to 3 inches above the walking platform.
Be careful to keep the walking belt centered. Then,
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Unplug unit then, using the hex key, turn both idler roller bolts clockwise,
edge of the walking belt 2 to 3 in. (5 to 7 cm) off
belt centered. Then, plug in the power cord, insert
properly tightened.
