There is a rear dust cover that sometimes gets stuck, this will make it almost impossible to lock the handle up. First locate the cover which is at the rear right above the wheels. It's about 2"x8" and ribbed vertically and slides up behind the rear panel of the lower body. If it's in there and stuck, just realign it with the 2 grooves on each side or remove it completely; it is a dust shield after all. The best fix is to replace the rear panel and dust shield and they are ordered together and the cost is fairly low. Also check the alignment of the rear body panel at the bottom There are 2 tabs that protrude down about and inch on each side, the one closest to the handle release lever sometimes gets bent and causes the unit to jam. If this does not help there is one more solution involving the rear wheel assembly. check to see that the rear wheel axel is straight, meaning both wheels are parallel at all times while releasing the handle. If the axel is crooked, the wheel assembly must be replaced and you should have a Miele service center order the part and do it for you.
SOURCE: the foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
SOURCE: NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
SOURCE: Dyson DC28 Air Muscle Vacuum that is stuck in upright position
This turns out to be an easy fix.
First, get some graphite lube.
Lay the vac on it's 'face'.
1) On the underside of the vacuum, there is a 1/2" wide 'groove" in the motor housing, that runs up the centerline of the machine. Follow this groove from the front of the machine towards the back. As you follow it 'up' into the machine, the groove will 'end'. Just past this point there will be a small black plastic piece with little 'ears' that is resting in another groove that continues just past the point where the first groove ended. This is the upright position lock that isn't releasing. (I've painted the 'ears' red in the attached photo)
2) Using a screwdriver, or butter knife, etc, gently lift this piece out of the groove. The vacuum head should now easily tilt down like it should.
3) Flip the vacuum over onto it's 'back' and you will be able to see the grooves, now visible on the front of the lower head. Apply the graphite to the smaller (upper) groove and try working the unit in and out of the upright position several times to work the graphite into the locking mechanism
SOURCE: dyson wont staND UPRIGHT
Hi its Darran at Dyson.
So that we can help resolve this, please call our Helpline on 0800 298 0298. One of our advisors can through some simple checks with you which will hopefully resolve the problem.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
