Hi there!
You can set an alarm to alert you once, or daily at a specified time. Once set, the alarms are easy to change or turn off completely.
1. In Idle mode, press Menu > Tools > Alarms. The following options appear in the display:
• Wake-up Alarm
• Alarm 1
• Alarm 2
• Alarm 3
• Alarm 4
2. Select an Alarm. The alarm screen appears in the display containing the following options: the alarm name, the on/off setting, the time, AM/PM, alert type, alarm tone options, the alarm volume setting, days if the week to sound, snooze option and auto power on/off setting.
3. Highlight the options you wish to change, then select values for the options using the Left and Right navigation keys.
4. When you're finished entering and selecting values for the alarm, press ok. The alarm is set and the alarm icon appears in the top of the display.
Hope this helps
Set an alarm on the Samsung T255G Phone: Go to Menu, tools, alarms. Highlight the alarm you wish to set using the up/down keys (for example wake up alarm, alarm 1, etc.) and press "OK." The first option you have is to name the alarm if you wish. After you name the alarm, use the down button to go into the yellow area and then the right/left buttons to set the alarm to "on." Right after you've done that, press the down button again to get your other options such as time, a.m. or p.m., alert sound, etc. Hit "save" and you should have your customized alarm set. Hope this helps - it was a real pain trying to figure it out but once I did I wanted to share it since a lot of people were having problems with it.
