Kenmore 22422 Top Load Washer Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore topload washer 70 series heavy duty will fill with water and start the washing cycle but when it gets to the drain and rinse cycle it wont go any further on any washing cycle
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on May 01, 2011
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1029780
Points
10654
The lid switch controls the rinse and spin cycles.
If the lid switch is bad the cycle fails to advance.
Replace your lid switch.
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
2helpful
4helpful
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
2answers
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
1helpful
Won't spin or drain
Check to make sure your lid switch is working.
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
2answers
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
I also need the answer...
where is the lint trap located
Alexander
vince
