Hi, I purchased a pre-owned Invicta Coalition Forces Sniper watch and the trigger is broken... Any idea who may be able to repair the watch? I've read horror stories regarding Invicta's Service Center in Hollywood Florida... Nice watch but as you may be aware the watch will not work properly without the trigger arm in place...
Reggie
SOURCE: Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
First, you need to set the hands at midnight. Press the upper button for 3 secs and let go. The hands will start to advance. Watch them, and when you are almost at the position of 00:00:00, press the upper button again briefly and the hands will stop. Then pulse the upper button to finish advancing the second hand to a perfect 00:00:00. Within 10 seconds, press the middle, knurled, button briefly (if you don’t, the watch will just to back to where it was). When you have done this, the watch will start to run (albeit at the wrong time).
Now you need to tell it to set itself from the time signal. Press the upper button and the lowest one *at the same time* for 3 secs and let go. The watch will acknowledge your request by moving the second hand (only) to 12. Leave the watch somewhere it is likely to get good radio reception. In a few minutes, you will see its hands start to move to the correct time, and they will eventually get there and your watch will be working again.
SOURCE: need operating manual to set time and date
Just posting a solution to remove this from unsolved problems list. thanks and good luck.
SOURCE: how to set time on Harajuku Lovers digital watch
See, you just have to hold the blue button (in TIME 1 "T1") till the screen tell you "LIGTH OFF", then push the green button and u will see all the option.
i found it by myself... i took time but i did it...
i hope this can help u...
see ya....
