Question about Mackie 1604 Vlz3 16 Channel Mixer
What is the best way to run a Bass thrue the mixer , Mike the Amp or directley thrue the mixer, we had problems with a clear sound?
  • 635 Answers
The easiest way is to take the line out from the bass amp and connect it to the line in socket of the mixer ( not the XLR Mic in ). This will give a clean and flat sound which you will have to customize using the Mixer tone control and not the bass amp controls.
Posted on May 01, 2011
SOURCE:
How to trouble shoot Hofner Icon Series Bass
Hi!
If replacing the jack did't clear it up, and the cable and amp checkout OK, my best guess would be either a solder connection on the pots and switches, or a dirty pot or switch. I'd reflow all solder points and use DeOxit 5 on the pots and switches. Use it sparingly trying to flow it inside the components. Then operate the pots/switches a number of times quickly. Do your best to keep it off the finish. Do not spray it into the pickups.
Good Luck!
May 06, 2014 | Hofner Icon Series Violin Beatle Bass...
Tip
Home Studio Recording: Part 3
Once again, we dive into the subject of recording your band's (or your solo) album. So far, we've covered the basics, and how to record drums. Today, we talk about the all-important Bass Guitar.
There are a few different ways that you can do this, one being the industry studio standard of using a Direct In box, or DI. How this works is you run through this box, which then has two cables. One to the mixer, and one to your amp. You then mic the amp (see below for mic placement), and get both the clean and amped signals together on the track, giving you a fuller sound.
Method number 2 - Amp your bass, and add the effects there at the amp. Compression, chorus, and distortion are some popular ones with the bass guitar these days, even in country music. Light overdrive gives a bass more high end sparkle, making it easier to hear it at the lower volumes.
Method number 3, and suggested if you don't have a DI box as well as if you don't want to anger your neighbors, who bang on the ceiling with a broom (just joking on that. Still, don't tick them off!) - Plug your bass straight into the computer, and record two tracks simultaneously. On one of the tracks, apply an amp simulator with the desired effects. On the other, apply ONLY an equalizer and compressor, in that order. What this does is gives you the amp tone, as well as accentuates the lower frequencies of the bass guitar. It's the shortcut that actually produces great results.
For mic placement on your amp, you can use either a condenser mic (which requires a preamp, or a mixer with phantom power), or a dynamic mic. Both will give you a great sound, but it's up to you to find what fits your sound, and your budget.
Placing the mic. - Pick your best sounding speaker. To do this, turn your amp down, and play a note. Go to it, and listen to each speaker by placing your ear directly in front of it (this is why we said turn it down). If your best one is close to the floor, rotate the cab so that it's one of the top speakers. Using a standard mic stand, place the mic so that it's pointed directly at the speaker, but it's about 2 inches in front of the cone, and 2 inches to the side. You can experiment with different placements, such as directly in front, or to the side and pointed across the speaker, but this is usually the best sound you'll get.
That's all for this segment of Home Studio Recording. Join us later for part 4.
on Mar 27, 2011 | Music
How to connect Mackie Mixer 1402vlz4 to Bose Accoustimass 5 speaker
you need a power amplifier between the mixer and the speakers to actually drive the speakers. You would have to choose which amp to use (the manual, found here: http://www.bose.ca/controller?url=/shop_online/speakers/stereo_speakers/acoustimass_5/index.jsp#manuals suggests between 10-200 WRMS for power), and thus would have to determine the cabling options depending on the amp you choose, but...go from either the MAIN or CONTROL ROOM outputs of the Mackie mixer into the inputs of the power amp. Then go from the outputs of the power amp to the inputs on the Acoustimass bass module, which also runs the Acoustimass satellite speakers.
Apr 17, 2014 | Music
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Behringer djx700 has no bass
Check that all the eqs are set not to cut bass, check there are no effects on and that the XPQ is off. If you still have the problem how sure are you there is no bass coming from the mixer? Have you tried it with another amp? We had one hire customer who had the same problem you describe and his amp had a crossover and it was set to act as a mid/top amp and wasn't giving him any bass, unsurprisingly, switching it back to full range sorted it.
Dec 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have 2 x jbl jrx 115 and 2 x jbl jrx 118s, we set up a power amp to desk and the 118s, into the left hand speakon connection, using a speakon to speakon cable, from the 118s a speakon cable is run out...
In spite of your description it is not quite clear of the connections... In general you should limit the number of speakers connected to an amp output to a maximum of two. I am not sure if you might have more than that in your daisy chain. Let's go over another important thing: are ALL of the amps and the mixer (desk?) powered from the SAME receptacle or power conditioning module? If not, make it so even if you have to run extension cords. The ground bounce of building power at venues can destroy your equipment. The brand/model of the amp(s) and the mixer would be useful to analyzing the problem. It is unlikely the failing battery in a guitar would kill one side of the PA. If the amp is overloaded, the thermal cutout may be disabling part of the amp and the system. Also please verify the RMS capability of your amp. You want the power of the amp to NOT exceed the rating of the speakers USE RMS VALUES... not the fakey "program" or "peak" ratings... those are just advertising gimmiks to show my numbers are bigger than yours... we know that game...
Sep 18, 2011 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
How to get a fat and clear sound from schecter
Ninety percent of what you want depends on the amp and speaker you are using.
You likely will want a 15 inch speaker in a bass cabinet to start with and a decent midrange driver as well.
No amount of EQ will fix an audio system that just can't put out the bass tones.
Nov 14, 2009 | Schecter Stiletto Deluxe-4 Bass
Hi have a pmp3000 what are the most suitable bass bins and tops (speakers) to use for a two piece 60s band with semi acoustic guitar and a bass, irun the bass through a 15'' h and k bass amp and i bring a...
Have you considered any of the Behringer cabinets that are recommended companion pieces for this mixer. For more expensive gear have a look at JBL cabinets. The EON series is good. Have a look at what other bands you know are using and listen to their sound to see if its what you like.
Oct 27, 2009 | Music
Mackie 1604 Vlz3 16 Channel Mixer Logo
88 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
