It sounds more like a backlight problem to me. The first thing I would try before tearing the set apart is simply unplugging it for about five minutes and plug it back in. TV's do weird things sometimes and need to be reset. Odds are, if you have to open up the TV, there's not a whole lot you can do anyway. Check the backlight on signal and also see if your inverter is working. I would suspect that if you're strobing your backlight is probably dying. In that case all you can do is replace the panel; you could try finding a replacement backlight and installing it, but I wouldn't advise even trying this. Replacing backlights is quite a task if you're not familiar with televisions. Anyway, best of luck.
