Hi.. i'm using Microsoft windows xp professional SP2. virus attacked my windows and done a lot of damage to my windows though i have NOD32 3.650 antivirus fully updated but it couldn't remove it. it named ckvo.exe & ckvo.dll and i removed it manually by deleting it from registry and from system folders but now i can't open any of my hard disk drive, every time i tried to open it, "open with" box appeared. what should i do to solve this problem? i heard it can be done by just formatting one of my hard disk drive other than c: on which windows is installed. is it true?
You need to stop the service from running before you go any further...
click start>run type in 'regedit' then navigate to
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
Diable it from running. You can also do this by start>run type in 'gpedit.msc' and looking for the entry there, then disabling it
Once you have done that restart your machine, then look for every file on the HDD relating to ckvo.exe and deleting it. Check your %temp% folder and registry as well. When you think you have all the files empty the recycle bin, delete the key from the registry and restart the pc again.
Check to see if you can access you HDD as normal.
I cannot say for sure if this works, but it it is worth a try.
Do a google search for Malwarebytes' Anti-Malware, there is a free version available, I believe Cnet Downloads have it on their site, install and update then run it, there is a good chance that the program will pick up the virus and remove it for you.
The virus probably has infected the autorun.inf file at the root of the c:/ drive
Delete this file, which is a hidden system file, then restart the machine and try to access the drive again from 'my computer'
the autorun.inf file is a system file and is protected so you may have to do it from a command prompt.
Or a quick way is to use diskheal http://www.luqsoft.com/diskheal/download...
download it and run it and it will fix the 'open with' error.
Hope this sorts you out, let me know.
Try to remove with linux. You could best use the ubuntu live CD to remove it. It can be found here http://www.ubuntu.com/ . Burn it on a CD or DVD and boot it from your boot menu. You must press try ubuntu so you can delete the virus from your harddisk.
Asunsoft Word Password Recovery is one of the most popular Word Password Recovery tool in the market, which can help you crack a password of Word in whichever versions, 97, 2003, 2007 or 2010. A password made up of less than 3 characters can be recovered within 1 second. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack, so that it can greatly shorten the recovery time if you partially remember your password.
Asunsoft Office Password Recovery is an all-in one MS document password recovery tool which can crack password of Microsoft Word, Microsoft Excel, Microsoft PowerPoint, Microsoft Access, and Microsoft Outlook. It offers a professional set of features wrapped in a very user-friendly form that is easy to master. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack.
Asunsoft Word Password Remover is a must-have password recovery tool which has the highest speed for you to crack Word password and has 100% recovery rate. The usage is very simple that you just need to click OPEN button to import a locked Word document and click Remove. Seconds later you can open it without password.
Open Symantec.com and download Norton2007(Anti Virus) or u Can Try With E-Scan (Antivirus)
Gizmo1
i already removed that malware as i mentioned before and now i am trying to recover my windows. i cant open directly any disk drive in my computer folder. everytime i double click on c:\ or any other drive an "open with" box opens which also dont have "always use that application to open this file" option. it still opens when i use "folders" or "explore" option in toolbar. help me to fix this problem.
hi..
