You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
SOURCE: My EWC13D4 remote isn't working properly
Your remote is bad that you know. Is it worth fixing it> No, Highly unlikly. A universal remote for about 10 bucks can be used to change channels and volume as well as the on and off funtions BUT a universal remote will not work the menu or any of the other feture. Go to the link I posted here to find your remote you need to get... good Luckhttp://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=EWC13D4&brand_pn=EMERSON_EWC13D4&mode=large&uid=1156107437374
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
SOURCE: Screen is blank with sound working
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
SOURCE: Remote doesn't work
Check out my solution here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
It's for the 37" version, but also works for the 26" TVs with little variation.
Hope it helps,
Ryan
