Have you checked to see that you've set the correct resolution for your desktop?
The specifications say that the laptop's display can show 1024x768 pixels.
http://www.toshiba-europe.com/computers/products/notebooks/tecra9000/index.htm
Set it to that first. Anywhere below that resolution (for example 800x600) may be causing black borders on your screen.
Hope this helps!
-BuzzPuppy
SOURCE: black border around games
Dear milly, so is it clear that this happens on all games or just some? tell me a little more about your system and games you play, I'll try and help. JLS
SOURCE: Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Testimonial: "thanks!"
SOURCE: my screen will not fit the monitor on my lap
enter your bios settings at startup (push del, F2 or F10) and set the vga output to stretched.
SOURCE: black borders around my windows screen
got to control panel, desktop settings and select the type of resolution you prefer. there are option settings that you would like to prefer.
