Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
SOURCE: Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
SOURCE: Water in the detergent, fabric softener, bleach dispensers
If it's not leaking outside I wouldn't worry
SOURCE: Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
SOURCE: bleach and fabric softner despenser liquids not being used.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
