Using the Camera
* 1 Attach the USB cable to the camera. Open the small, rubber door on the side of the camera body and plug the corresponding end of the USB cable into the slot on the camera.
* 2 Plug the USB end of the cable into the computer. Make sure the cable is securely attached to both the camera and the computer.
* 3 Turn the camera on. This will open software to download your images. You will be able to move the images from the camera to the computer and choose whether to remove the images from the card.
* 4 Select the option to download or transfer images. This will depend on what type of operating system you are running and may vary if you are running third-party image processing software, such as software that came with your camera.
Using a Card Reader
* 1 Turn the camera off and remove the memory card carefully.
* 2 Insert the card securely into the card reader slot.
* 3 If necessary, turn on the card reader. This will open the software to remove images from the card and place them onto your computer.
* 4 Select the option to download or transfer your images.
