Jabra Bluetooth Headset - BT2070 Logo
Posted on Apr 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant use my jabra BT2070 what is the password for pairing update????
Michael Vincent Cruz
Level 3:
Guru:
  • Master 868 Answers
  • Posted on Apr 30, 2011
Master
Level 3:
Guru:
Answers
868
Questions
Helped
273599
Points
2414
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
I can't pair my Jabra BT2070 to my LG 260.
Turn off the headset.
Hold the call/power button on the headset to make it discoverable.
Add it from your LG.
Use pin 0000.
How can i connect my jabra bt2070 with my computer running windows 7?
You can buy a bluetooth usb adapter and make your pc bluetooth enabled. I bought an I/o gear blue tooth adapter for $ 2.58 and it allows me to pair up my headset to my pc and I can go up to 500 ft away and hear perfectly.
All you need are 2.0 usb ports (high speed)
the adapter can cost up to $ 20 but it works and boy is it worth it!
4helpful
How to reset a password
Try 0000, that should be a default code.
If not then It is possible to reset and test the headset. Make sure that the
headset is powered off. Press and hold the answer/end button
and the on/off button at the same time for 10 seconds.
The headset will automatically turn off after approx. 10 seconds.
The next time you power on, the headset will go into pairing
mode as the first time you powered your new BT2070 on
Hope this helps.
Thanks
1helpful
Cant remember paring passcode
The pairing passcode is 4 zeros "0000"
5helpful
2answers
Cannot get my phone to recognize the device. need steps 1,2,3
Here is the link pages 4and5 (http://img9.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf)
My jabra bt2070 won't let me talk on the ps3 it only blinks. What do i do?
i'm assuming youve paired it with the ps3, but have changed the input device in audio device settings? try that. and check this:
http://cnettv.cnet.com/use-any-bluetooth-headset-your-ps3/9742-1_53-50004665.html
hope it helps. ciao.
How to do pairing
my jabra bluetooth dose not show any mobile.how dose i maintain it it is a bt2070 plz send me sloustion my id is [email protected]
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
