SOURCE: I've had 2 crashed iriver X20
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
SOURCE: My IRiver MP4 is stuck on "Build Library"
ive searched for hours, i couldnt find a solution..
but i will buy it off you for $30
..i like pulling things apart.. lol
anyway, if your interested, ill pay for postage too, contact me
[email protected]
SOURCE: frozen iriver screen
this problem seems to be common
it can happen if you dont safely remove the iriver from the computer
i havent found a fix for this problem anywhere
but ill purchace your iriver if you cant find a fix..
my contact is [email protected]
