No, that fan is cookin'! > Spinning too fast.
The Sanyo A38001-001 from Intel, is only designed to spin in those RPM's when the Processor is REALLY Hot!
Usual RPM's are around 1750 to 1850.
A) Did you just buy and install this Heatsink/Fan combo?
1) If so, did you thoroughly clean the top of the Processor's case?
Used a scraping implement like a plastic credit card to scrape off the old Thermal Paste, and then used Q-tips dipped in Isopropy Alcohol?
[ Also know as Rubbing alcohol. 91% is best, but 70% will do in a pinch. Make sure it's dry afterward though. {91 percent alcohol, 9 percent Water, or 70 percent alcohol and 30 percent Water)
The Q-tips dipped in alcohol will wipe up the gooey mess of thermal paste. Usually takes quite a few Q-tips.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a well ventilated area with No sparks or flames present.
2) You did apply Thermal Paste, and correctly?
One small drop about the size of a large pea, in the middle of the top of the Processor's case.
Then set the Heatsink/Fan combo on top of the Processor, and tighten the screws down in a Criss-cross fashion
3) Tighten one screw down one turn. Go to the Opposite Corner, tighten that screw down one turn.
Skip over and tighten the other two screws down one turn as detailed above. You are tightening in an X pattern.
Make SURE the Heatsink's bottom is flat and level on top of the Processor's case.
If it is tilted even slightly, the heat transference won't be worth writing home to Mom about.
The Processor will overheat, and the fan will spin at high RPM's.
4) Is the Fan cable (Wires) plugged into the motherboard tightly? Plugged into the correct fan connector on the motherboard? (CPU_FAN)
Does the motherboard's Cpu fan connector have the same number of pins needed, as the fan cable connector requires?
B) If this Heatsink/Fan combo, (Sanyo A38001-001) has been installed for quite some time, check to see if the Thermal Paste has dried up, or is drying up.
Since 2004?
Yep, you better pull that Sanyo A38001-001 off, and check the Thermal Paste.
Computer unplugged from power, OBSERVE Anti-Static Precautions.
A Processor is the most susceptible hardware component to Static shock.
Clean the Processor and bottom of the Heatsink as stated above. Properly apply fresh, new Thermal Paste.
Example of Thermal Paste. (Maybe there is a 'Mom and Pop' computer store near you, that you can buy a one Processor application, for around $2)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=16826&CatId=503Check for a loose Cpu fan cable connection.
Make sure the Heatsink/Fan combo is seated tightly on the Processor.
Have any further questions please post in a Comment.
Regards,
joecoolvette
