Master
- Posted on Apr 30, 2011
Re: I have whirlpool A CLASS fridge how do i reverse the...
- I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
- You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
- There are some little clips that hinge the screws on the top and bottom of each handle.
- Remove these little covers with a small flathead screwdriver.
- Now remove the screws holding the freezer and refrigerator handles on.
- Now pop the screw hole covers on the side of the frig/freezer you will using.
- Now place and fasten with screws the handles on the other side of the frig/freezer door.
- Now remove the top freezer hinge first by removing the 3 screws on top.
- Now pull up on the hinge (save the spacer).
- Now pull up on the freezer door.
- Now remove the screws on the middle hinge.
- Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
- Now pull up on the frig door and set to the side.
- Now remove the screws on the bottom hinge (save the spacer).
- Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
- Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
- Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
- Fasten the middle hinge.
- Place freezer door on the middle hinge.
- Put the freezer door in it's natural position to make putting the top hinge on possible.
- Screw the top hinge in.
- Job complete.
Regards,
Tony
