Your feeder wheels need to be cleaned, open it up yourself from diagrams online, locate the feeder wheels, remove them, clean them with rubbing alcohol and a lint free rag, that will take care of the problem, if however the wheels are worn or how chips in them, then you can order the replacement parts
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
SOURCE: new cartridge won't print
re-seat the black cartidge, do head cleaning, get a windows test page (go to printers and faxes then right click on the printer icon and choose properties, click the print test page button).
replacing ink cart is the next step or service.
SOURCE: cannon MP210 printer
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
