Do you have the phone with an answering machine like:
http://www.generalmanual.com/Telephones/GE-25932EE1-Cordless-5-8GHz-Edge-Phone.htm
Or are you using a voice mail system on your phone line? If so, contact the voicemail company or your phone company for information on how to change the number of rings before the forward.
EJ Kudelka
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
SOURCE: The phone rings 3 times and goes to voicemail on
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
press feature "00" to logout
SOURCE: Nortel T3716E send calls to voicemail HELP!
Sounds like the call forward no answer isn;t set up on your extension. The first thing to do is to find out what the voice mail pilot number is. That's done by pressing feature 982. The display should say "set:xxx". The set number provided is the voicemail pilot number.
Next you'll need to enter system programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number.
Enter extension number you want to change call forward no answer on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press theshow key (top right arrow)..
The display should say none. Press the chng key and enter in the voice mail pilot number.
press the show key again (top right arrow) To review the rings til forward. Press the chng key if you wish to change the ammount of rings til answered.
Press the release key when finished
