I hope the problem isn't with your speaker. Have you tried the speaker on another computer or on a DVD player etc..? If it works, well can you adjust the sound from the sound settings or from the "Sound" icon on the Taskbar on your Desktop? If you can't adjust sound from Sound Settings (under control panel) or from the Taskbar's sound icon, then you might have missed to install the sound driver. Try reinstalling the sound driver and make sure the installation is successful. I also hope that you didn't do anything on your motherboard. You can also try plugging in the speaker jack to the front audio port or to the rear or vice versa. These are the things you may try at the moment. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
