Roland DR-3 - DR. RHYTHM Drum Machine DR3 Logo
Posted on Apr 29, 2011
Boss DR 770 Dr Rhythm will not turn on. I bought a new power adapter but that didn' solve the problem.
1 Related Answer
Anonymous
  • 62 Answers
  • Posted on Apr 05, 2009
SOURCE: cant find the manual without it being a pdf file
The Steps
1. Go to: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man and download the manual in PDF format.
2. Open the file in Adobe 9.0.0.
3. Choose File --> Save as Text...
4. You now have a fully editable copy of the User Manual.
OR...
1. Go to: http://somepdf.com/ and download the "free" PDF to Word converter program.
2. Install the program (be sure to scan download for viruses before installation).
3. Run the program and follow the prompts to covert your file. This program will attempt to keep all images and formatting intact when converting, unlike the above mentioned process.
OpenSource13
The record button on my DR-670 Dr. Rhythm drum machine no longer works, it has benn sitting for quite a while . It has been well protected in it's original packaging. Any help would be appreciated
YOu can disassemble the machine and clean the switch and resolver the connections to the circuit board, but it would be easier to call Roland and get the info for the nearest service center in your area.
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Backlight on boss dr 880 failed
IM LOOKING FOR A LCD BACKLIGTH REPLACEMENT PART
Need operating manual for BOSS Dr. Rhythm Section DR-5
Here is one link:http://cms.rolandus.com/assets/media/pdf/dr5_turbo.pdf Here is more:http://www.rubiconsystems.com/paul/dr5faq.htm
Jun 28, 2010 • Boss Music
Internal battery has come loose and requires refitting and or replacement. There are no service agents in my area and I'll have to do the job myself. Are there any instructions/manuals available for this...
If it is a drum machine, why have you posted this query under Cameras ? You may get more help posting it under musical (and I use the term loosely) instruments.
Cant find the manual without it being a pdf file
The Steps
OR...
OpenSource13
2helpful
2answers
KORG Rhythm 55 Instruction Manual For Drum Machine
The DR-55 is a Boss DR. Rhythm. I don't know of a Korg 55 drum machine. Are you sure?
Top Roland Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Roland Camera Expert? Answer questions, earn points and help others
