WHAT OS? XP?
learn to use the control panel. (more later)
the special keys like this can fail for 3 reasons (get it serviced)?
click start.
click control panel
see sound?
now click tab sounds
in the top roller button , pick no sounds (bingo all sounds gone)
error sounds and all
or pick any sound seen there, and make it go dead, or change it to any thing, (endless, choices) even sound of silence. is possible
like this , nosound.wav.
or to pindrop.wav
SOURCE: black screen will not boot up
The DV's all have pretty serious issues as a whole. DV1000's are currently under investigation for class action and I could give them info to add about 20 more model numbers but these are not my suit. The one with the power light flashing try a new adapter first but I'm sceptical. Weve seen way too many of these in and they like to short components are kill Maxim chips for PMU..
SOURCE: Laptop will not even boot up, won't turn on
Bad capacitors are the most likely devil... take this unit to a good electronics repair shop and have them run diagnostics on power side of board
SOURCE: HP dv6000 boot problem
Not a software problem, neither because of 'evil windoze'. HP has accepted a critical hardware problem, you can find it here.. http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&dlc=en&product=1842155&lang=en&docname=c01087277
There is no solution other than take it to the nearest service center. You may get lucky if you keep it on for a long time, so that the BIOS comes up!
SOURCE: hp dv 7-1135nr speaker won't work, headphones do
I suddenly got the same problem on my dv4-1120us today.. However by updating the audio driver to this one it started working again:
ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41616.exe
You better take a look at HP's website.. maybe you will need a slightly different driver, since your computer is not exactly the same as mine. I'm sure the sound card is the same, but better safe than sorry. good luck!
SOURCE: I have a Compaq CQ50 laptop, there seems to be a
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
