JVC Everio G Camcorder Logo
Posted on Aug 11, 2008
Sd card capacity on JVC GZ-mg37AA
Hi, Wondering if possible to get 4gb sd card for Cam
Regards Peter
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Sep 20, 2008
Anonymous
Contributor
Level 1:
Answers
26
Questions
Helped
4194
Points
32
You can buy up to an 8 gb sd card i saw them in walmart and radio shack
What is the maximum SD capacity that jvc everio gz mg57 can support?
You may use any size SD card. Bear in mind that SD cards only go up to 2GB. This camera will not work with higher-capacity SDHC cards.
tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 • Computers & Internet
I have JVC GZ-MG20EK and when I insert the SD card, it keeps saying I dont have a memory card in there?
Make sure you have an SD card, 2GB or smaller. This camera will not work with higher-capacity SDHC cards.
What does it mean when I get a message that says "please insert memory card" on my JVC Everio GZ-MG21U?
Make sure you're using an SD card, not a higher-capacity SDHC card. The GZ-MG21U works with SD cards, not with SDHC cards.
Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
3helpful
I have the JVC above and it requires an SD card. I inserted an SDHC card and it gave me an error. SD and SDHC are not the same? When I did try to but SD card only still on its label has SDHC. To be honest...
You are correct. SD and SDHC are not the same.
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
Memory card error replaced card but still get error message?
Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
Hi i cant find out what the maximum size micro sd card i can use in my jvc evario gz-mg365
The official line from JVC is
To record video, a microSDHC card with Class 4 or higher performance is required. microSD memory cards (256MB to 2GB) and microSDHC memory cards (4GB) have been tested for the following brands: Panasonic, Toshiba, SanDisk, ATP. No others have been officially tested and can therefore be guarenteed to work
1helpful
Jvc everio GZ-MC500 does not recognize High capacity SD
Beyond 2GB SD Card this model can not support. Why? because this model carries the logo SD, where as 2gb is the maximum, although there are some companies manufacturing SD with the capacity of more 2 GB but this is illegal(not standard for SD) do not conform with SD. New models can support HCSD (High Capacity SD) as far as 32GB can be found in the market. Hope this helps
2answers
I have a JVC Everio GZ-MG21EK Camcorder can anyone tell me the maximum sd card that you can use with this camcorder
There is no limit beyond the limits of the SD cards themselves. The JVC Everio GZ-MG21EK camera DOES NOT support SDHC cards, so you are restricted to the smaller capacities of the non-SDHC SD cards. I am successfully using a 2GB SD card in this model.
Stewart
Aug 03, 2008 • JVC Cameras
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
