How to reinstall heating elements. not sure about the wiring.
The electrical
specifications are based
on 220 volts. It should
be noted that higher
voltage will increase
power, just as lower
voltage will have the
reverse effect. The
(POWER MODE CONTROL) can
be adjusted to
compensate allowing the
user to increase or
decrease water
temperature. For best
performance adjust
temperature at MEDIUM
FLOW (approximately 1
GPM) this is the average
water flow at any faucet
with an aerator.
Remember, that any
adjustments made on your
unit will take seconds
to reach point of use.
DO NOT OVER HEAT WATER.
Water temperature from
105F to 120F is adequate
for all practical
purposes
MODELS
Model
Max KW at 220V
Volts
Max Amps at 220V
N-120
11.8KW
220V
54
N-100
10.8KW
220V
49
N-85
8.5KW
220V
38
N-75
7.5KW
220V
34
N-64
6.4KW
220V
29
N-42
4.2KW
220V
19
N-10
3.2KW
110V
29*
