Boss Rc 50 Logo
Posted on Apr 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why are my exported wav audio recordings so quiet (almost muted) when i replay it on my computer? It is this way when i record in both stereo and mono. When i export it and then play it on my pc through the media player, the volume is very very low...I ve cranked up all volume controls on my computer as well....is this the nature of a wav file...how can i boost up the volume? please help
Anonymous
Level 3:
Guru:
  • Master 722 Answers
  • Posted on Jun 19, 2011
Anonymous
Master
Level 3:
Guru:
Answers
722
Questions
11
Helped
282289
Points
2127
Make sure that the file format is the same, first. If so, try converting the format from wav. to a more recent format type, such as mp3, or mp4 if possible. This may help, as the computer may recognize it better depending on the program you are playing them with.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support @ Fixya.com
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 • Music
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 • Boss Rc 50
2helpful
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
When u export the track down too a wav.form and i convert it too mp3. if i listen too it in headphones i can only hear the vocals in the right earbud.
Well, did you run the vocals through a mixer and send to BOTH channels of the Lexicon Alpha? If you connect the mic to only one channel you will only get one channel UNLESS you process the .wav file and PAN the vocal channel into both channels when outputing to your MP3.
1helpful
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
2answers
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Recording problem on pa800
It seems as though it may just be a sample issue.I have had this similar problem before,because each drum hit corresponds to a key on the piano.It could also be the program you are using to open it.
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
