Vacuums Logo
Posted on Apr 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Equity Weather Station model 31215B and i was wondering if the outside wireless thermometer is waterproof .
Anonymous
Level 2:
  • Expert 273 Answers
  • Posted on Apr 29, 2011
Anonymous
Expert
Level 2:
Answers
273
Questions
Helped
123461
Points
865
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Testimonial: "Thanks the information given was very helpful"
  • Anonymous May 02, 2011
    I'm glad to help. Thank you so much for taking the time to respond.
2answers
How to keep my oreck xl bag docking station attached. bought
Put smaller part of bag docking system on first. Seperate it from the other. It has to be pushed on past plastic lip around hole. It should feel very tight. Then attach larger part of bag dock onto the smaller one.
I recently purchased and installed an Oregon Scientific Model WMR200A. The rain gauge worked for the first rain fall but it has not worked since. Today we probably got 3 inches of rain but it registered ...
Oregon Scientific has an FAQ webpage for your weather station:
http://us.oregonscientific.com/service/faq.asp?t=1&cid=2
There are several Q & As that are pertinent to your problem.
I hope this helped you.
Jul 19, 2011 • Vacuums
I need the manual for this digital weather station
Go to google.com. You will eneter the required problem. Your problem will be easily solved
May 29, 2011 • Vacuums
2helpful
How to set location on IT Works KW9007B weather station
its easy press & hold mode key after flashing time ress mode key again and again till reach london city which is default then press + key set your city and press mode again
Apr 19, 2011 • Vacuums
I have a Midland Public alert weather radio Model # WR-300 Problem is lost the DC in power pack. Wondering what the DC input voltage and current are for this model. I have some power packs but want the...
It takes 4 AA batteries, that is 6 volts. You will find that a 6V 500Ma power supply will be the right thing, just make sure that the polarity of the plug is right!
Feb 11, 2011 • Vacuums
2answers
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Nov 10, 2010 • Vacuums
I'm trying to find a manual for my weather genius EM3302A indoor/outdoor remote thermometer, purchased from XS Cargo. I need the manual to tell me how to change the clock from a 24 hour clock to the 12...
Weather Genius EM3302A Remote Weather Station
Once all settings are complete you press the UP button to toggle back and forth between the 24 hour clock and the 12 hour clock.
Sep 23, 2010 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
