Goldstar DH304 Dehumidifier Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Apr 29, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103387
Points
14643
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
The dehumidifier motor is on but only extracts tablespoonfuls of moisture from the air every 48 hours. In other words it isn't functioning as it should. Model #DH40; traceability code GR and barcode...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
The dehum runs smoothly, no extra noise. The problem is no water is condensed into the reservoir. Is this fixable?
heatman101
I have a goldstar just like the one on the front a friend gave it to me i only hear it once in a while is that what it is suppose to do,, to **** water out of a basement...
heatman101
I have Goldstar modle # DH 305y7 it does not run
heatman101
Runs for a couple minute then shuts off
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
The dehumidifier is plugged in and turned on, but isn't running.
heatman101
Dehumidifier keeps blowing circuit
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Need a upc code for a DH304
heatman101
2helpful
Won't collect water
heatman101
Top Goldstar Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
