This is usually caused by a clogged drain filter. Here is a link that should help F21 Fault Code Repair
This problem is a good illustration of how there's just no substitute for actual hand-to-hand combat with broken appliances. Here's an excerpt from the service manual on this fault code: EXPLANATION AND RECOMMENDED PROCEDURE F21 LONG DRAIN
If the drain time exceeds eight minutes the water valves turn off.
NOTES: After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
I've worked on dozens of these washers and have only found the above service manual solution to apply once or twice. The vast majority of the time, I'd arrive and all the washer would do is drain and flash F-21 in the display. I couldn't even get the control board to go into diagnostic mode.
Using my keen Samurai Insight®, I unplugged the washer and removed the molex connector from the water level switch (also called a pressure switch). To get to it, remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right there on top, as seen in the picture below:
Anyway, I plugged the washer back in and, lo!, the washer did enter diagnostic mode and the people did sing and the Lord did grin. And there was much rejoicing. Especially after I replaced the water level switch where up on applian to logical harmony was restored.
Hope this helps (remember to rate and comment this answer)..
