Vtech Cordless 6041 Phone Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my code to change my voicemail greeting. how can i reset it?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Sep 08, 2011
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444082
Points
622693
The 6041 isn't an answering machine. If you have an answering machine connected to your phone, consult its documentation (or post a new question here, specifying the make and model of the machine). If you subscribe to an answering service offered by your phone company, contact them for instructions and help.
Model TC 25250 RE - how to retrieve outgoing greeting? Phone was disconnected and than I plugged in and greeting/outgoing is lost?? I was told I can retrieve it?? Can you help??
Change your greeting To use a different greeting that you already recorded or switch back to the default greeting:
  1. Open the Google Voice app .
  2. At the top left, tap Menu Settings.
  3. In the Voicemail section, tap Voicemail greeting.
  4. Next to the greeting you want to use, tap More Set as active
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
1helpful
DTU-16D-2
Voicemail is usually ext 200 or 300 if it's not assigned on a speed dial button. If your ext has a mailbox assigned the voicemail will greet you or ask for your code. If you don't know the code your voicemail administrator will have to reset the password or mailbox. If your ext doesn't have a mailbox assigned, then it will just give you the main greeting that outside callers get.
Reset voicemail password on toshiba phone dp5122-sd
1. Enter your voicemail Code. This is like an extension which dials voicemail (mine is 750).
2. # *
3. 999 #
4. 999997 # (this is the default password, but it might have been changed. contact your phone company for the password)
5. 8
6. Follow the prompts. You will need the DN number for the phone. Also, select "Reset Security Code", not "Reset Mailbox". Resetting the mailbox will erase ALL data from the mailbox (voicemails, greetings, names, passwords).
I hope this helps!
4helpful
Need to change main greeting and wipe out an old unknown password
Start here for the Auto Attendant greeting. http://dstech1.com/changing-the-greeting-on-voicemail/
Once you figure out what voicemail this is, you will need to go into Voicemail Admin Programming to re-initialize the password for an extension.
Main greeting
When you log into the voicemail, what does the lady say?
Welcome to Merlin mail, merlin messaging, Audix???
Need to know the voicemail model....
1helpful
I need to change the main company greeting
dial voicemail, when prompted for mailbox
99#
1234#
9
3 for AA
1 for day 2 for night
6 to modify menu
press star (*) pound (#) (you arent messing with selector codes
record greeting there. 21 to rerecord, 23 to listen
Make sure you press # to save when finished
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i found, helped me out
1helpful
2answers
Nokia 5185
In order to change your voicemail message you need to call into your voicemail system. Voicemail is not actually in the phone but a service where your calls are forwarded to. Most voicemail systems will play the main menu if you press the * key. One of them should be about a greeting. Check with your carrier for specifics.
Feb 03, 2008 • Nokia 5185i
2answers
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
