Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
SOURCE: Refrigerator freezer is not freezing, all items
Hi Check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running.If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
However there are various reasons as to why refrigerator is not cooling. Please check this link to get an in-depth knowledge related to your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.htm
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
