Hi and welcome to FixYa, I am Kelly
The BSI550 came in 4 model types 0, 1, 2, and 3.
Types 2 and 3 are brushless. I am assuming this is a brushless generator and the following list of parts can cause the unit to suddenly stop working.
1. Capacitor(s) This unit has _ capacitors
Usually when capacitors fail on a brushless generator you first start noticing that when there is a load introduced that voltage changes dramatically. However they can just up and quit.
2. Diode pack
3. Wiring from the capacitor to the stator is damaged.
4. The Varistor in the rotor has failed (this fails because of a short in the rotor)
5. Rotor short or open
6 Stator winding short or open.
My years of experience with brushless generators is the 2 most common failures (other than wiring that happens alot) are the Rotor and the capacitors in that order. Rotors fail out of the blue... capacitors usually do not. Take a look inside the control panel. If you notice that the bottom of the the end cap enclosure looks like someone dripped candle wax in it you most likely have a failed capacitor. I probe the capacitor(s) with one terminal removed watching for a brief spike in resistance on the meter and then it drifts to infinity EACH time the meter leads are reversed. (Good result usually). After that is is on to
wiring, Rotor and stator resistance tests.
Parts:
http://www.ereplacementparts.com/images/Porter_Cable/BSI550-W_TYPE_0.pdf
Thanks for choosing FixYa,
Kelly
