JVC AV-32S575 32" TV Logo
Posted on Apr 27, 2011
I own a D series 36 inch year 2000 JVC. it stopped running in mid program, and the red power light keeps blinking. we unplugged and replugged after 8 hours, but same result.
amd64online
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Apr 27, 2011
amd64online
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
6148
Points
98
Your power supply has failed.
I have JVC 52 inch HDTV and changed my light now after 4 years. It just blinks, does not turn on. what do I do
Tries tv unplug,replug it back like an hour later.The tv now it resetting itself back to the factory setting.The tv now,should work.Not,than the tv power supply board have problems and is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I was watching tv and it just shut off now the power light is blinking red and a clicking noise is coming from the tv. It wont stop unless I unplug it
i chaged some flyback on that model. you can unsolder b+ of fbt and replace with a 75 watt bulb to see if power supply or fbt.
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
1helpful
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
2helpful
4answers
Wont power up, red blinking light (on timer)
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
