if you have external speakers, try adjusting the volume there!
If you don't, then click on icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",
Adjust the settings for device/s you use to hear sound.
What type of laptop HP , ASUS , COMPAQ , ACER ?.......... Up the
Volume on My HP Laptop
Open the "Start" menu and click on the
"Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either
"Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the
slider.
If you need to decrease the volume, simply move the slider
bar down.
Click on "OK" when finished and close the
"Control Panel" window.
Click on the speaker icon in the bottom-right corner of the
screen for a faster volume adjustment. Simply move the slider bar up to
increase the volume and move it back down to decrease the volume.
Volume on an Acer
Laptop
Acer laptops are typically sold with
pre-installed Windows operating systems that offer sound-adjustment features
for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem
with external speakers or headphones to increase the volume, as well as mute
all sound on the laptop.
If the computer should output an unusually low volume,
fixing the problem may be no more involved than sliding a control switch with
the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner
to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to
drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control
to open another window with volume controls for "Speakers" and
"Applications," adjusting each slide control upward to increase the
volume.
Be sure the speaker icon below each control is not
accidentally muted.
Click once on each speaker icon to remove the red circle
with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the
lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select
"Adjust Sounds" from the Hardware and Sounds category.
Try resetting the sound card defaults. I guess the easiest way to do this is to delete anything related to sound from "Device Manager" then reboot your system and wait for windows to re-install the sound drivers again, this should happen automatically without your intervention. hope this helps
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar hope this helps
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
i just starting having the same problem this morning- think it's saying F61 and acorrding to the manual you should check and correct the speaker cable connections- and if that doesn't work call the dealer
