SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
SOURCE: dryer
Derf, E1 means an open thermistor. If this is a front loader, remove the lower panel by removing the 3 screws on the bottom panel. The thermistor will be sitting right behind the blower housing next to a white thermal fuse. The thermistor is the black one. If this is a standard model the lower panel should open by sliding a puddy knife on the two clips and pulling foward. The thermistor is in the same place as a front loader. Your part number should be 3976615. An easy job. Don't forget to kill the power to the unit when repairing...Good luck.
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
SOURCE: Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
