Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot remove the brush roller on the Shark Navigator Lift-Away. It has thread caught in it that cannot be removed without actual removing the brush roller.
Think Crucial
Level 3:
Master:
  • Euro-Pro Master 894 Answers
  • Posted on May 08, 2014
Think Crucial
Euro-Pro Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711290
Points
8395
Hi, it's Ambrai from Crucial Vacuum.
Your Shark NV22 has small wheels underneath the head of the vacuum that need to be popped out. The wheels hide screws that need to be taken out along with the three other visible screws. Using a flat and sturdy object, pry out the wheels. After unscrewing all of the screws, you will be able remove the cover and access your brush roller.
While you're repairing your Shark NV22, why not replace your hose and/or filters? For optimal performance, it is recommended that you change your filter every three to six months.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv22&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
5 Related Answers
Anonymous
  • Posted on Jul 05, 2011
SOURCE: THE ROLLER ON MY SHARK
We have only had our Navigator for 6 months and the bar won't turn. We took the whole beater bar head apart and it was a wiring problem in the beater bar motor.
What a piece of junk this is, very poorly made and has many design flaws.
Looking for something now to take it's place!
Anonymous
  • 76 Answers
  • Posted on Apr 19, 2009
SOURCE: How do I take off the roller brush on my Eureka
the screws are on the top.
A
Anonymous
  • Posted on Jan 02, 2008
SOURCE: Kenmore canister model 116
Yes. Remove the top plate on the power head. Remove the two screws. Flip the power head over. Insert a flat head screw driver into each of the marked slots and separate the two pieces. It takes about 2 minutes.
Anonymous
  • Posted on May 22, 2010
SOURCE: shark navigator n22
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Anonymous
  • 3640 Answers
  • Posted on Mar 09, 2011
SOURCE: My beater brush comes on
sounds like the belt for the brush is either broken or streatched out. replace it!
Roll brush on the shark navigator lift awat
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Think Crucial Customer Care
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Ihavea shark nv lift-away pro the brush dont spin an the light dont light up it caught a floor vent wean this started . is ther a reseat if so ware is it
Sounds like you broke the brush belt. Easy to replace and most come with a replacement attached somewhere on the vacuum. The light is probably just burned out from the impact
Stripped screw on shark navigator plate
drill the head down to the shaft of the screw then remove plate, remove remainder of screw if possible, fit new screw.
Dec 30, 2013 • Vacuums
1helpful
I cannot remove the roller brush for shark vacuum
Remove the rubber "bumper" material from the outer edge. Small slits are exposed where the roller is attached to the rest of the vacuum. u can figure the rest out. I wedged my finger in between the roller edge and lower plate. Use whatever you want. Hope that helps.
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
