There are two scenarios whereby a BlackBerry smartphone user is unable to log into BlackBerry World with the BlackBerry ID when the SIM card has been removed from the smartphone.
If the SIM card is removed from a smartphone where a BlackBerry ID has not been previously set up, then the option to skip the login to BlackBerry ID will be available.
If the SIM card is removed from a smartphone where a BlackBerry ID has already been set up, then the option to skip the login to BlackBerry ID will not be available. The BlackBerry smartphone user will be required to log in with the last known BlackBerry ID credentials.
Workaround
If the BlackBerry ID password has been forgotten but the answer to the password recovery question is known, select Forgot Password on the smartphone and answer the recovery question to generate a password reset email.
If the BlackBerry smartphone user knows the email address used for the BlackBerry ID login but is unable to remember the associated password then it is possible to reset the password using the steps below:
Note:If the BlackBerry ID account is not confirmed, it is necessary to provide the answer to the password recovery question as part of the web based password reset flow.
To see if a BlackBerry ID account is confirmed, log in to the BlackBerry ID account, select Account Details and locate the Email Status field.
Enter the BlackBerry ID Username (email address) and the CAPTCHA characters, then click Submit.
Enter the Answer to the Password Recovery Question, then click OK.
Note: Answering the recovery question is only required if the BlackBerry ID account is not confirmed.
A confirmation message will be displayed A password reset email has been sent to [email protected], at which point, a reset email will be delivered to the associated email address inbox.
Log in to the email account associated to the BlackBerry ID using the desktop browser, BlackBerry Browser on the smartphone, or the Browser on the BlackBerry PlayBook.
Locate the password reset email and select the Change your BlackBerry ID password link.
Note: The BlackBerry ID reset email will come from [email protected]. If the email is not found in the inbox, check the mailbox's Spam or Junk folder.
When the password reset page loads, enter the Answer to the Password Recovery Question, enter the New Password, Confirm Password, then click Submit.
A confirmation message will display once the changes have been saved successfully.
Moving forward use the newly created password whenever logging into BlackBerry ID.
From the BlackBerry ID login screen on the smartphone select Forgot Password.
Enter the BlackBerry ID Username and select OK.
Enter the answer to the password recovery question and select OK.
A confirmation will display Your BlackBerry ID Password Recovery email has been sent to[email protected] or Instructions for resetting your password have been sent to your email address.
Access the associated mailbox, locate the password reset email, and select the Change your BlackBerry ID password link. Note: The BlackBerry ID reset email will come from [email protected]. If the email is not found in the email account inbox, check the Spam or Junk folder
When the password reset page loads, enter the New Password, Confirm Password, then clickSubmit.
Moving forward use the newly created password whenever logging into the BlackBerry ID.
Actually, someone tried to log in to your FB account using your credentials.. so FB admin has to verify that you are the right person , so it sends an E-mail to you FB associated mail.. whatever you have to do is to login to you E-mail account and from there you'll see a mail from zynga asks you to verify yourself. .and by pressing a button named "Verify" it directly switches you to you FB account and after that you can access your poker app..
Hi - i just had the same problem and it took a bit o jiggery pokery but ended up i went into one of the games and then i think by either pressing start or select the game was paused and gave options - i went down to "sprachen" and ticked that - this seems to have worked. Hope this helps.
you can click the forgot my yahoo id button on the log in page and it will send your information to your alternate email if its asks for a security question then Anwer it as clearly as possible ,I hope ive helped you . Good luck!!!
even if you mistakenly joined a domain you can still log in through your existing id and password.
Once your press CTRL+ALT+DEL, you will see a login window with three fields namely: user id, password and Domain.
In the log in screen use the drop-down menu in front of Domain (which shows your new domain- most likey MSHome) and choose 'this computer'. After this, enter your old/existing user id and password and hit enter.
Please proceed to your system settings and change your domain back to Workgroup. Restart PC.
i have problem in yahoo messanger signing, my email is opening but messanger not logged in. i also change password but still same problem, from the same messanger i logged on another id but it work and only my id is not working.
I've sent u the recovered Gmail login details from ur recovered mail ID to your new mail IDs (Gmail and Yahoo)...
It is working now,... Thanks to Fixya.com
Thanks to the GMail team, who helped to recover the password
But, someone is really trying to have access to this mail ID of u....B'cos, when iwas logging in now to send you mail with details, i was asked for 'captcha' figure recognition, so...please take care of the security of the ID, as soon as u gain access
PLEASE DO CHANGE ALL THE ACCESS PASSWORDS AND ALTERNATE IDs RELATED TO THIS G-Mail ID, immediately after u log in
Bye Take care
PS: I am not mailing u from my mail ID, bcos....afterall this is 'the NET' :)
