I have a alba lcd32880hdf television,which is just out of warranty,our problem is that whe u turn tv on after a couple of secounds we lose the picture and the screen goes black but we still have perfect sound,can u help us?
The inverter is what powers your backlight. If the backlight is shorting/opening intermittently because of age or if your inverter is no longer able to sustain the power needed by the backlight your TV may go black.The inverter is what powers your backlight. If the backlight is shorting/opening intermittently because of age or if your inverter is no longer able to sustain the power needed by the backlight your TV may go black.
You can't post conmments that contain an email address.
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
The Tv is working fine, from the description it is that one channel not coming in, the blue screen indicates no signal. It could be that the signal in that room is a little weaker and just going below the thresh hold to allow it to come through. It is possible the station might have been off the air, try another auto tune.
When you said this:
They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
