Question about Panasonic PV-GS300 Mini DV Digital Camcorder
Error message "push the reset switch"
We can't use our camera because of the error message"push the reset switch", which doesn't go away after you push the reset button.
  • 2 more comments
  • jwwj316 Oct 05, 2008
    same problem
  • michael7705 Oct 28, 2008
    tape won't play... PRESS RESET BUTTON message appears
  • Anonymous Feb 02, 2009
    Same problem. Thanks panasonic for not solutions.
  • Anonymous Apr 03, 2009
    same issue - sometimes reset works, sometimes it doesn't. It seems unpredictable
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
Posted on Sep 15, 2008
    Problem Solver:
  • 18 Answers
Hmmm.....
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Posted on Feb 04, 2009
SOURCE:
How do you get to the shutter release on a d3100 to manualy turn it to get the error message to go away
Try switching the camera on and while it is on remove the battery. Leave it for 30 secs and replace the battery then switch it of and then on. This process sometime clears Error Codes.
Oct 05, 2014 | Nikon D3100 Digital Camera
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
After some shots an ERR message appeared on LCD, I could not make more picture. The error message in the counter field (when half pressing) the shutter is r09. I tried to take in and back the battery, the...
"ERR" doesn't indicate any specific error, but usually tends to be something only a technician can fix. Sometimes, you can make it go away by fully pressing the shutter release, but chances are that it will reappear at some point. Take it to a reputable camera shop, or send it to Nikon if you're still under warranty.
(The "r09" message is not an error, but an indicator of how many images you can take-nine in this case-before the camera has to pause for processing. This usually applies to burst-mode photography, and varies depending on how fast your CF card can transfer images.)
May 15, 2011 | Nikon D80 Digital Camera
I have had my Intova IC 600 for almost a year. Recently I was getting a "Card Error" message. I replaced the card, but the message won't go away. I have tried to reset the defaults, but the message won't...
You probably just need to format the card in the camera to get it to work. This will erase the card so download any pics first using a card reader if necessary.
Mar 28, 2010 | iClick Intova IC800 Digital Camera
Push the reset switch
The means that the powerup self test is not completing successfully. If there is no error indication in the viewfinder, this unit will need to see a Panasonic servicer for repair.
Dan
Oct 19, 2009 | Panasonic NV-MD10000 Camcorder
I have a canon rebel xti, I partially blocked the pop-up flash while taking a picture. There is an error message on the screen - flash error 05, turn camera off and on again to clear. It is not working....
You can reset all your settings and clear errors by removing the battery pack and also under the camera is an access screw to get to a button battery or two. The type of screw you use a dime or quarter to open. With the battery pack out, remove the button batteries and leave all those out for several minutes and then with the batteries still out, activate the On switch for your camera and leave it in the full on position for 30 seconds. That should drain off all residual power from the circuit board inside. You will have to reset everything, such as your personal settings in Tools and the time and date setting. All of those user set items, but your error message should clear too. If you get the error message again, right away, after reinstalling the batteries and battery pack, then you have damaged the Flash Unit... but I doubt that. Canon makes a good camera and I don't think what you describe would cause that problem.
Regards,
Worldvet
Jan 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
"Push the reset switch"
I had the same problem with the 'push the rest button' on the display after the tape mechanism jammed up against the tape compartment cover. I figured there was probably a mechanical error, possibly a switch. I dissassembled the camcorder and found the tape compartment cover switch was sticking. Here's how to fix it with some photos to illustrate:
1. Open the tape compartment door and remove the screws in the small plastic cover (fig. 1). Remember to look a which screw came from each hole as they are all different.
2. Remove the plastic part from above the tape mechanism (fig. 2)
3. Remove the screw above the front grip belt mount (fig. 3)
4. Remove the screw above the mic (fig. 4)
5. Remove the battery and take out the screw at the top left under the viewfinder (fig. 5)
6. Take out the screws under the LCD monitor (fig. 6)
7. Remove the two screws from the front underside of the camera body (fig. 7)
8. Now you can slide the front of the camera, together with the curved aluminium top section away from the main body of the camera (fig. 8)
9. It is possible to reach the switch with the front moved forward slightly, but it is possible to take the front off entirely by removing the wiring ribbon with the green tab (fig. 9)
10. Clean the brown switch at the bottom left of the exposed camera front with a soft brush/air (fig. 10 )
11. Reassembly is the reverse of the above procedure.
Hopefully this will mean no more frustration with the 'press reset button' screen.steviedeee.jpgsteviedeee_0.jpgsteviedeee_1.jpgsteviedeee_2.jpgsteviedeee_3.jpgsteviedeee_4.jpgsteviedeee_5.jpgsteviedeee_6.jpgsteviedeee_7.jpgsteviedeee_8.jpg
Jan 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Open Questions:
Panasonic PV-GS300 Mini DV Digital Camcorder Logo
727 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
