I plug in the charger and nothing happens. i was able to charge it awhile back but now for some reason it won't do a thing. i tried charging it with a usb cable and still nothing happens, what do i need to do to make it work?
Mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
I bought a charger at radio shack that charges the battery directly since the home and car chargers weren't working and my phone is back in business. yes!!
Try your sidekick 2 battery in a different phone, and see what happen. If the second phone turn on then, you know the problem is with your device. also you can check the usb port to see if any pins are missing from the rubber mount if so there may be your problem good luck.
Yall just need to get a new charger. since it wont charging anymore or
it stopped working like yall said.
it that help, please rate it.
thanks.
Mines freaking doing that too.
In order for mine to charge it has to be in a certain spot and now it just stopped so Im using the USB cord and it'll charge all freaking night but have like two batteries in the morning :/
any help?
please?
sidekick 2 won't charge
my sidekick was charging fine then i looked at it and it just stopped charging. so what should i do.
My sidekick 2 used to work if I just angeled the charger and forced it in at a certain way, but now that doesnt even work, and its really pissing me off.
