It is something that you can repair yourself
You probably have a tensioner that has broken.
I am sorry but I do not have the Samsung routing available to me.
Below is a chart of the most common routing of dryer belts.
The part that has failed on your unit is probably the idler pulley/brackett.
You should be able to repair it without having to remove the drum
http://www.applianceaid.com/images/belt-config.JPG
Unplug the dryer and pull it out from the wall.
Remove the top of the dryer by opening the door and taking out the screws along the top of the opening, then lifting the top. Remove the front of the dryer by reaching down into the opening at the top and taking out the screws holding the front in place. Move the front piece out of the way just enough so you can get to the drum inside, without disconnecting the electrical wires running from the front piece to the unit.
Move to the back of the dryer and remove the screws holding on the small access panel at the bottom. Remove the panel. This will give access to the two pulleys holding the thin belt that runs around the drum. With your pencil and paper, draw a diagram showing exactly how the pulleys are strung. Then slip the belt off the pulleys so it's hanging loosely on the drum.
Return to the front of the dry and pull the belt off the drum from the front. Put the new belt on the drum from the front, laying the ribbed side against the surface of the drum.
Return to the back of the dryer and restring the belt through the two pulleys, using your diagram as a guide. Use your hands to manually turn the drum at least one full turn to make sure the belt is lined up.
Things You'll Need
Disconnect the power for your dryer before beginning any work. It can be disconnected from the wall outlet.
Open the top of your dryer cabinet and tilt it backward.
Use a Phillips head screwdriver remove the top two screws. Put the screws in a safe place.
Tilt the front forward and roll the belt around the drum.
Remove the old belt by lifting the drum slightly in order to give way to the front supports. You may have to open the dryer door to help the belt fall to the bottom of the basket.
Position the new belt by aligning it in the correct position before beginning to thread it through the motor pulley and idler. It will take someone with strong fingers and skinny arms to be able to get past the drum in the front. The dryer belt in a General Electric dryer has to be threaded looking in from the back.
Reassemble your dryer by replacing the screws in the top of your dryer.
Close the top and slide the dryer back against the wall.
Reconnect the power to your dryer by plugging the cord back into the wall outlet.
