Question about HP DeskJet D1460 InkJet Printer
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could you please suggest some of the reasons for the light to blink other than cartridge anamoly or a way to solve this problem. Thanks
    New Friend:
  • 70 Answers
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Posted on Apr 26, 2011
6ya staff
SOURCE:
Blinking light
Try to Reinstall the cartridge , if the blinking continue , try to remove ink then unplug the power cord and reconnecting power cord with ink then see blinking for ink , then install the cartridges , if hope this help
Mohamed Hejazi
Afaqnama - Tripoli, Libya
IPG@hplibya.com
Mar 20, 2013 | HP DeskJet 5150 InkJet Printer
Power light is blinking: no paper jammed HP DeskJet D1460
Hi
The power light is blinking because one of your cartridges are bad. Hence need replacement. Try with the black cartridge as normally this goes bad.
Jul 21, 2011 | HP DeskJet D1460 InkJet Printer
HP Deskjet D1460 - Does not print. Continuous blinking power light when turned on, with or without being connected to a computer. Under normal circumstances, shouldn't the printer power up &...
the obvious fault is a lack of communication between the computer and the printer from not having the correct driver installed
using microsoft drivers can lead to problems so it is best if you go on the HP web site , select the driver download for you model and install the driver direct
you can also right clivk on the printer and then click on properties tab , click on compatibility tab then click in the box and high light the win os you are using to rectify compatibility problems
Oct 21, 2017 | HP DeskJet D1460 InkJet Printer
My hp d1460 is power light is blanking how can i sovle thish problem ?
The Power light (c01602202.gif) might blink (flash) or be off. A blinking Power light indicates thatthe product requires maintenance, or is in an error state.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859305&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=2510644#N221....
Check this link on how to resolve these problems
Nov 17, 2010 | HP DeskJet D1460 InkJet Printer
Light blinking
1. there is document in the queue but paper is out
2. Cartridge problem (remove and insert again)
3. Communication error
4. Cover is open
Nov 09, 2010 | HP DeskJet D1460 InkJet Printer
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
Hpdeskjet problem
A light blinking under the cancel button usually indicates a problem with the color cartridge.
Go to this page for instructions on resolving that issue - about halfway down the page is a picture of your printer control panel with both the left and right light blinking. The section explains that it's to help if "One or both print cartridge status lights are on and blinking."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368924&cc=us&lc=en&dlc=en&product=3374277
Jun 04, 2010 | HP DeskJet D2560 InkJet Printer
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
I believe this is normal with HP deskjets. I have a different model but HP deskjet 3740, which also gives a blinking light when there is a pending print job and or printer has run out of paper. I usually get rid of this problem by putting some paper and most importantly removing and re-plugging the printer power cord (which does a basic power reset on the printer and causes a refresh of pending print jobs). I hope this works for you too.
Jan 27, 2009 | HP DeskJet D1460 InkJet Printer
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet D1460 InkJet Printer Logo
587 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
