SanDisk Sansa Clip MP3 Player Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Sansa clip + Mp3 player ...... I want to charge it without using any computer or laptop .... can I use an external Ac adaptor for charging ...?????? n also I want to know the charging specifications .. that it takes 110 volts or 220 volts ....
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Apr 26, 2011
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
14787
Points
141
Yes, you can use an external AC charger to charge it. The charging specification is between 100-240V 50HZ. So your mp3 is safe for charging. Goodluck.
Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
2helpful
2answers
How to charge sansa clip when computer doesn't recognize it
Go to the SanDisk website for drivers; select Sansa for product, choose your operating system from the other scroll down menu. Download and install software. Also if using Windows, make sure your windows media player is the latest version.
Alternativly you can use a AC to USB adapter to plug your Sansa Cable into a wall jack.
Will not recharge
Have you tried plugging this into a USB2.0 port ? sometimes, some of the usb ports dont not have enough power to charge some players.
Which is which is why, sometimes, (seen very often with external hard drivers) there are two usb plugs on the computer side which needs to be connected.
1) Try another USB port, or another computer (especially is this is a laptop, some of the ports are under powered, to save power)
2) if you have an AC Adaptor to charge this, try it with that
5helpful
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
My sansa e250 could not be detected on my computer
In Normal conditions, after plugging in the MP3, amd waiting one or two minutes, the device should be installed automatically by the system. This works in the same way on Vista and on XP. On Windows 98 and Me the device may not work. After the MP3 is installed, you can reach the Sansa under My Computer (Computer). It will be displayed as an external disk named Sansa. If you are using an USB extension or an USB external hub, get rid of it. Try plugging the MP3 to a different USB port. Try unplugging AC charger, and removing laptop batter for ten minutes, sometimes this can fix problems caused by accumulation of electrostatic charges on USB controller. If that does not solve the problem, test a different USB device on the same laptop, and test the MP3 on a different computer. Either one may be faulty. If the problem is the laptop you may fix it by removing and reinstalling USB root hub on hardware devices in Control Panel.
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Won't fully charge on a belkin mp3 player ac adapter?
Call Sansa and order the proprietary chargers for this device, unless you want to ruin your player.
Sandisk Sansa clip
You need the latest firmware update from Sansa' website - may require a restart of computer after performing.
Battery wont charge with an AC adaptor
Dear Verona,
Sandisk is a brand that is best used with its own. There are two degrees of separation here. 1) It is a cell phone charger
2) The charger is not in its family.
With both things working against the machine, it is not a surprise it will not fully charge.
Happy Surfing!
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
