SOURCE: is it possible to salvage a water damaged sony
Yes- first thing, remove the battery. Second thing, tilt it on its side so the water drains out. Leave it alone for at least 48 hours. If it is salvageable, it should work once it's dried out
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Testimonial: "quick responce and very good answer I highly recommend"
SOURCE: how to change language in
To change the phone language:
1 From the home screen, drag upwards
2 Find an tab setting > Locale & text > Select Locale.
3 Select an option of language u wish to change...
SOURCE: cant send&receive mms on xperia
sir you need mms settings for sending and receiving messages. so kindly contact customer care executive and get settings for it. save it as default. then it will be normal sir, this will solve your problem sir. thank you
SOURCE: I bought xperia x10 mini
make sure you have Skype, not the Jar version, but the Android APK version.
there is a useful forum here and please post back for followup.
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
Problem is only with the internet calls, usual calls are working fine.
