Sony VAIO PC Desktop Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One time cooling fan caused sony laptop to black out. right now, changing desktop picture caused cooling fan to start heating up. shut down some opened programs and it is all right. what is the problem? don't want to send it back to sony and risk everything being un-installed, otherwise i would be happy to replace fan. any other suggestions and what is my risk to my 6 week old laptop if i don't do this?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
96
Points
Vaio laptops came with this malfunction from factory, it's a flaw in the system, shame that vaio wont fix this for free, since is their problem to begin with...just a thought...mf.!!!
Anonymous
Level 3:
  • Sony Master 32,281 Answers
  • Posted on Apr 26, 2011
Anonymous
Sony Master
Level 3:
Answers
32281
Questions
Helped
7913152
Points
102259
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Hp 300 12z. Desktop i relocated and plugged everything back in. I push power button and the fans start to run however after 45 seconds they shut off and screen goes black. What could be wrong.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
tip
How to stop over heating laptops or computers.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
The most common cause of laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your laptop. This causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just Hot. Laptops get hot. It's what they do. However, if your laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link...
laptop over heating Google Search
on Oct 24, 2017 • Computers & Internet
HP 620 laptop shut down and won't start
4helpful
3answers
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
I have an Hp pavilion slimline s3100n pc and after a while, it just shuts off with no warning whatsoever. When I try to turn it back on, it just shuts right back off. It's like I have to wait for it to...
Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
I have a VGN-FJ 270 and the cooling fan does not work anymore causing the laptop to heat up and shut down. Any suggestions?
search for a cooling fan for that model in google or ebay. If you can't find one you may be able to buy one of those cooling systems that you set the laptop on to pull all the heat out of it. I did that once to my brothers old laptop and it is still working today.
Laptop switched off while i was working on it
After the notebook shuts down do not turn it back on for 15 minutes and then test it again. Will the notebook work longer if you let it cool down for a while? Isn’t it hot if you touch the bottom? Can you hear the fan running?
Most likely you experience a laptop overheating problem and it would be fixed by cleaning the cooling module – the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on. The cooling module helps to keep the CPU cool when the laptop is working. The cooling module includes two parts: the heat sink and the cooling fan. The heat sink is attached to the CPU and helps to conduct the heat from the processor to the radiator. The cooling fan blows on the radiator and helps to disperse the heat produced by the CPU. The laptop will overheat if the heat sink radiator is clogged with lint and dust or if the cooling fan stopped spinning.
If your laptop shuts down after some time without any reason and warning, check if the cooling fan spins. Usually it makes some noise and you can hear it. If the fan works fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air, just blow inside the fan openings on the laptop bottom. If the heatsink is completely clogged, then it is necessary to remove the heatsink for cleaning.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!  uva
2answers
Problem of frequently shutdown unexpectedly for m6810 laptop ........When fan starts after some temp. goes up to 53 C. it causes....
laptops/notebooks tend to overheat more quickly the desktop resulting in shut down, try a laptop/notebook cooling fan
Laptop shuts off after powered on omnibook 6000 It runs for a few seconds and shuts down .... it that a bad power supply or what?
You might have a broken or dirty CPU fan. The CPU heat sink fan is responsible to cool down your CPU while it is on. If it is broken or stuck(dirty), then your machine will power off automatically preventing CPU damage or worse-case-scenario:FIRE caused by "burnout".
Your CPU heat sink might not be mounted on your LT properly. Also causing overheating; thus shutting down.
Its a laptop right ? Right! Another thing you could try is to unplug the battery, and let it run from AC power only and see if it makes any difference.
Random shutting down
Your CPU is heating up it will shut down on you the fan that keeps it cool must of clapped out replace it. Then you should be right..
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
