SOURCE: USB Device Not Recognized for Palm Treo 680
if you are using Vista ultimate, it is a 64 bit operating system and therefore palm doesn't have official support for it yet, but someone has found a solution:
http://forums.palm.com/palm/board/message?board.id=windows_hotsync&thread.id=17980
SOURCE: Palm Z 22 Hand Held When
Troubleshooting for hotsync is provided in the link . Click the link below
Hotsync
SOURCE: Palm Z22 will not turn on
Well you can try a trickle charging on the device.Trickle charging is connecting the device to the computer using the USB cable and then let the device get charged using the computer power source, make sure that you charge the device for 6-8 hrs on the computer.
SOURCE: My Palm tungsten E2 hand held PDA is totally frozen and locked up
Best thing to do here is to remove any memory cards etc.. and do a hard reset - seems like soft reset will or has not worked...
Press and hold the power button - keep it pressed and gently press the reset button on the back of the handheld.
Wait for the Palm Powered logo to appear and release the power button.
You should get a message warning about erasing all data. Press up on your 5-way navigator to reset.
This will erase all data inlcuding user information from the device, but synchronizing should get it all back - but you will loose anything that was not recently sync'd
good luck
SOURCE: palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts back.
