Condensation occurs when warm, humid air is pulled across a cold fins of an air conditioner and blown out the front as cool, dry air.
What is happening with your air conditioner sounds to be normal operation - here's why:
The condensate usually drips onto the ground from traditional window air conditioner units or through a pipe to the ground from remote air handlers of split systems. Since yours has no place to drain away into soil or waste pipe, it is collected in a compartment that must be emptied, just like a dehumidifier. When the compartment is full, the unit shuts off - otherwise the compartment would overflow on the the flooring or carpet. This could be a very expensive repair if hardwood floors were damaged or carpeting were to become moldy. Even more so if the the space under yours were finished - like an apartment building or if you used this on the second floor of your home - and damage to the ceiling below were damaged.
You could operate the device if it were connected by a hose to a drain at or below the bottom of the connection point (a floor drain, shower drain, etc.) or if the unit were placed on a counter top and allowed to drain into a sink or other drain / waste pipe below the the hose connection point. The hose must not get higher than the connection point at the drain plug on the air conditioner to work properly.
I hope this helps and good luck.
