I have a Sharp AR-407 and after filling with more toner now gives me error message "Call for Service. Code:F2-00". Is there anything that I can do to bypass this message?
It sounds like you have a bad toner cartridge. There is a chip on the rear end of the toner that is sometimes defective. It doesnt happen often, but it happens. blog.equipmybiz.com
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
you have a problem with the chip on the toner cartridge you have to reset this via simulation 16! if it's a refilled one have the recycler do it and replace the chip if it's an oem ask sharp
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127 PRESS # PRESS = PRESS C PRESS = TYPE 16 PRESS ENTER BUTTON (the button for making photocopy) PRESS 'OK' TWICE Note: be fast in pressing all the buttons. FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
